Date/Time: Fri, 07 Feb 2025 14:53:50 +0000
How to add an alert based on multiple studies
View Count: 858
[2022-10-19 15:33:53]
BB.Boss - Posts: 5
How do I add an alert like an arrow for example, based on multiple studies?
I would like to have an alert when the Delta + the Delta Change is positive/negative + an imbalance cluster.
I have the studies of these 3 elements but how to make a common indicator for these 3 studies?
I add an image of my chart for a better understanding : https://www.sierrachart.com/image.php?Image=1666193506955.png
Thank you in advance!
[2022-10-19 20:51:16]
John - SC Support - Posts: 37808
To create an alert based on different studies, refer to the following:
Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart
To place an arrow on the chart when the alert is true, you would need to use the Color Bar Based on Alert Condition study. Specifically refer to the following section:
Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars
[2022-10-19 22:42:56]
BB.Boss - Posts: 5
Thank you very much for your help John I appreciate it, I will look at the links provided.
