Date/Time: Wed, 19 Mar 2025 03:26:43 +0000
Historical data download via SC-Data (delayed) feed (although Rhytmic data feed is used) ?
View Count: 333
[2022-10-19 14:47:27]
User355493 - Posts: 27
Is there a way to set this in SC so that historical data is loaded from the SC data feed and you are connected to the Rhytmic direct data feed at the same time ?
Background: Rhytmic blocks the download for one week if the amount of data exceeds 40GB in one week. When using multiple markets this can happen....
Loading via SC-Data (delayed) feed and then changing with "symbol translate" unfortunately does not work.
Best Regards
Matthias
[2022-10-19 20:41:16]
John - SC Support - Posts: 38782
No, we can not do this. This is how we used to have it, but there were too many issues and a lack of understanding such that we had to change and simplify, so the data from Rithmic is the data from Rithmic, and so on.
We recommend using our Denali Exchange Data Feed instead of the Rithmic data in order to avoid this issue. Refer to the following:
