Date/Time: Wed, 19 Mar 2025 09:11:18 +0000
Chart Replay Issues
View Count: 373
[2022-10-19 14:33:59] |
Marc_Law - Posts: 9 |
I'm having chart replay issues. I'm trying to replay stocks (NASDAQ, NYSE, AMEX) that gapped up recently. When I try to replay it; the chart is frozen and doesn't move. If I wait long enough it moves a little bit but then it refreezes again. If I replay it at a higher speed like 100+ then it moves constantly. However, this is too fast for me to find use for it. How do I make it so that it replays at normal speed when I do 1.00 or 5.00 or 10.00 or whatever and it not freezing up on me? |
[2022-10-19 15:07:11] |
Sierra_Chart Engineering - Posts: 18841 |
Make sure Sierra Chart is set to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Otherwise, what you see must make sense based upon the trading activity of the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-19 15:07:25
