Date/Time: Thu, 17 Sep 2026 09:45:42 +0000
no data on SC feed , or DTN Iq feed.
View Count: 712
| [2022-10-19 13:45:02] |
| jmftattoo - Posts: 106 |
Wondering whats goin on here, were 15 min into the day, and the SC feed all data is not loading SPY. DTN IQ feed is also not feeding live data. Checked my balances all is well there. wondering whats goin on
| [2022-10-19 14:18:45] |
| Sierra_Chart Engineering - Posts: 24882 |
Make sure you are using the right symbol. In the case of the Denali Data Feed, this would be SPY-NQTV. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-10-19 14:19:28] |
issue resolved. Dont know what or why, but everything just came online.
