Date/Time: Wed, 19 Mar 2025 09:39:45 +0000
Charts and buttons way too large
View Count: 523
[2022-10-18 21:18:04]
User653934 - Posts: 28
My charts are flowing off the page, the buttons are now too large everything is out of scale. I can't figure out what happened or how to fix it.
[2022-10-18 22:09:24]
John - SC Support - Posts: 38782
In general, if things are "too large", then you would need to adjust the font sizes down. You can access these on Global Settings >> Graphics Settings >> Fonts. Refer to the following:
Graphics Settings: Fonts and Text Appearance
[2022-10-19 00:20:11]
It's not the fonts that are too large, it's the charts flowing over the borders of the chartbook and the buttons of the control bar, all huge.
[2022-10-19 06:41:03]
Sierra_Chart Engineering - Posts: 18841
You can control the size of the Control Bar buttons through the font size used for those buttons:
Control Bar: Control Bar Buttons Size and Text Size
Regarding the size and position of the chart windows, we recommend using Window >> Cascade to resize them:
Window, CB and CW Menus: Cascade (Window)
