Date/Time: Wed, 19 Mar 2025 09:50:12 +0000
[User Discussion] - Reconstructed Tape Study Vertical
View Count: 680
[2022-10-18 20:57:01] |
Deltaxbt - Posts: 9 |
Hello i rebuild the Reconstructed Tape using the Large trade volume indicator. Now i wanted to ask if there is some way to make it look like a real time and sales (displayed vertically) I have seen someone doing this but couldn't find out how. It is also showing the time scale below. Thanks in advance. |
[2022-10-18 22:03:44] |
John - SC Support - Posts: 38782 |
You would just need to have the Input for Draw Mode for the Large Volume Trade Indicator set to one of the options that is not the Entire Bar. These will then give you the data at each price level within a bar. Refer to the information here: Large Volume Trade Indicator: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
