Date/Time: Fri, 02 Oct 2026 15:17:02 +0000
Show (highlight or draw horizontal line) the highest/lowest delta on a VbP Study
View Count: 809
| [2022-10-18 19:50:41] |
| dvant krypto - Posts: 43 |
Hello... When you have the VbP study set to show delta (Ask Vol. - Bid Vol.), is it possible to immediately show where the largest positive and negative deltas are and have that automatically change location as when a new larger positive/negative delta has been established, thus creating a range? Tx. Date Time Of Last Edit: 2022-10-18 19:57:10
| [2022-10-18 21:48:16] |
| John - SC Support - Posts: 48091 |
The only way to kind of do what you are wanting is to use the Color Code Volume Bars Based on Percentage of POC. The first thing is to set the Volume Bar Calculation Method to Ask Volume - Bid Volume and set the Bid Volume and Ask Volume Coloring Method to None. Then set Color Code Volume Bars Based on Percentage of POC to Yes. Then set the colors such that the 90-100% POC Color is the color of the greatest delta and the 0-10% POC Color is the color of the smallest delta. Set the other colors to whatever you want. This will then show you the largest delta and the smallest delta in the the colors you chose. The reason this is not perfect is that the coloring is a range of 90-100% and 0-10%, therefore you may not get just one bar colored. Refer to the documentation starting at the following: Volume By Price Study: Color Code Volume Bars Based on Percentage of POC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
