Date/Time: Mon, 03 Aug 2026 08:09:44 +0000
Denali Feed nasdaq rt exchange activated but not real time
View Count: 1008
| [2022-10-18 19:18:19] |
| User806947 - Posts: 10 |
Hello, I tried the self help threads for not seeing real time on my denali feed for stocks but none of the advice changed delay. I activated real time nasdaq today. I even tried logging off and on. Thanks
| [2022-10-18 21:14:42] |
| John - SC Support - Posts: 47426 |
Activating the NASDAQ TotalView exchange should resolve the issue. Since you are still having a problem, then we need to make sure that you are adding the -NQTV suffix to the symbols. This is necessary in order for us to know to give you the data from the NASDAQ TotalView instead of our older U.S. Stock exchange option. Refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes If the above is not the problem (i.e. you have the -NQTV in your symbols), then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-10-19 12:01:07] |
I tested the symbol WMT, and the following is a copy of the log below. Thanks for the help in trying to resolve why I am not receiving real time. As an aside, do I have to really add the suffix NQTV every time I enter a new stock symbol to review a chart in real time? It is just not that efficient. The second question that arose for me is I also saw there is documentation on 250 real time security symbols for a cost, but is that a past practice with Sierra Chart Data Exchange that is no longer the case with Denali Data Feed or is this the reason I am having trouble not getting real time data? I did read the documentation you linked me to and I had a third question. The third question is the Nasdaq TotalView doesn't show all of the trades, but only a fraction of the trades, and only the ones traded through Nasdaq??? I use the number/footprint charts and seeing all the orderflow is important to how I view a trade potential. Is there a different data feed that shows all the volume that transacts for stocks? Thanks for help with these three questions. I appreciate it. Software version: 2447 64-bit | 2022-10-19 07:57:54.982 Primary Thread ID: 16056 | 2022-10-19 07:57:54.982 Usage end date: 2023-04-20 | 2022-10-19 07:57:54.982 Enabled for: Advanced Features 2. | 2022-10-19 07:57:54.982 Enabled for: Sierra Chart Historical Data Service. | 2022-10-19 07:57:54.982 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-10-19 07:57:54.982 Enabled for: Delayed Denali Exchange Data Feed. | 2022-10-19 07:57:54.982 Enabled for exchange2: fairx_exchange.data | 2022-10-19 07:57:54.982 Enabled for exchange2: NASDAQ US stock data | 2022-10-19 07:57:54.982 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-10-19 07:57:54.982 Current selected Data/Trading service: SC Data - All Services | 2022-10-19 07:57:54.982 Custom symbol settings values: enabled | 2022-10-19 07:57:54.982 Chart Update Interval: 100 | 2022-10-19 07:57:54.982 Intraday Data Storage Time Unit: 0 | 2022-10-19 07:57:54.982 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-10-19 07:57:54.982 2022-10-19 11:57:54 Local computer time in UTC | 2022-10-19 07:57:54.982 2022-10-19 07:57:54 Local computer time in SC Time Zone | 2022-10-19 07:57:54.982 2022-10-18 18:47:18 Server time in UTC | 2022-10-19 07:57:54.982 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-10-19 07:57:54.982 Program path: C:\SierraChart\ | 2022-10-19 07:57:54.982 Data Files path: C:\SierraChart\Data\ | 2022-10-19 07:57:54.982 OS Version Number: 10.0 | 2022-10-19 07:57:54.982 Locale Setting: C | 2022-10-19 07:57:54.982 DLLs: delta_64.dll, gc5150_Studies_2417_64.dll, TicinoSuite_64.dll, UserContributedStudies_64.dll, VolMultiplier_64.dll | 2022-10-19 07:57:54.983 Allowed protected custom studies: TicinoSuite | 2022-10-19 07:57:54.983 Crash reporter started: true | 2022-10-19 07:57:54.983 File >> Disconnect selected. | 2022-10-19 07:58:26.837 SC Data - All Services | Waiting for socket receive thread to end | 2022-10-19 07:58:26.844 DTC Client socket (4) | CloseSocket call. | 2022-10-19 07:58:26.844 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-19 07:58:26.844 SC Data - All Services | Disconnected from the server. | 2022-10-19 07:58:26.844 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-10-19 07:58:26.844 DTC Client socket (3) | CloseSocket call. | 2022-10-19 07:58:26.844 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-10-19 07:58:26.844 SC Data - All Services | Disconnected. | 2022-10-19 07:58:26.845 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-19 07:58:26.845 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-10-19 07:58:26.881 DTC Client socket (4) | Closed. | 2022-10-19 07:58:26.881 SC Data - All Services | Connected to server complete. | 2022-10-19 07:58:32.559 Triggering next historical data download in queue. | 2022-10-19 07:58:32.559 Triggering next historical data download in queue. | 2022-10-19 07:58:32.559 Triggering next historical data download in queue. | 2022-10-19 07:58:32.559 Triggering next historical data download in queue. | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. SIZ22-COMEX | 2022-10-19 07:58:32.559 Mapping SIZ22-COMEX to SIZ22. Service code: comex | 2022-10-19 07:58:32.559 Using symbol data fast lookup vector | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Starting real-time market data updates for: SIZ22-COMEX (SIZ22). ID: 1 Service code: comex | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Requesting security definition data for: SIZ22-COMEX (SIZ22). ID: 1 | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Mapping ZNZ22-CBOT to ZNZ22. Service code: cbot | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZNZ22-CBOT (ZNZ22). ID: 2 Service code: cbot | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Requesting security definition data for: ZNZ22-CBOT (ZNZ22). ID: 2 | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ESZ22-CME | 2022-10-19 07:58:32.559 Mapping ESZ22-CME to ESZ22. Service code: cme | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESZ22-CME (ESZ22). ID: 3 Service code: cme | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Requesting security definition data for: ESZ22-CME (ESZ22). ID: 3 | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ESZ22-CME | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZBZ22-CBOT | 2022-10-19 07:58:32.559 Mapping ZBZ22-CBOT to ZBZ22. Service code: cbot | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZBZ22-CBOT (ZBZ22). ID: 4 Service code: cbot | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Requesting security definition data for: ZBZ22-CBOT (ZBZ22). ID: 4 | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. CLZ22-NYMEX | 2022-10-19 07:58:32.559 Mapping CLZ22-NYMEX to CLZ22. Service code: nymex | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLZ22-NYMEX (CLZ22). ID: 5 Service code: nymex | 2022-10-19 07:58:32.559 SC DTC Delayed Exchange Data | Requesting security definition data for: CLZ22-NYMEX (CLZ22). ID: 5 | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ESZ22-CME | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZBZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ESZ22-CME | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ESZ22-CME | 2022-10-19 07:58:32.559 Subscribing to symbol for symbol alert. ZNZ22-CBOT | 2022-10-19 07:58:32.559 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2022-10-19 07:58:32.559 No download requests in the queue to start downloads for. | 2022-10-19 07:58:32.566 No download requests in the queue to start downloads for. | 2022-10-19 07:58:32.566 No download requests in the queue to start downloads for. | 2022-10-19 07:58:32.566 No download requests in the queue to start downloads for. | 2022-10-19 07:58:32.566 DTC Client socket (1) | Creating socket. | 2022-10-19 07:58:32.576 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-19 07:58:32.576 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2022-10-19 07:58:32.576 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-10-19 07:58:32.596 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-10-19 07:58:32.596 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-19 07:58:32.596 SC Data - All Services | Starting real-time market data updates for: SPY. ID: 6 Service code: equities.us | 2022-10-19 07:58:32.618 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: SPY | 2022-10-19 07:58:32.618 SC Data - All Services | Requesting security definition data for: SPY. ID: 6 | 2022-10-19 07:58:32.618 Added historical Intraday data request for SPY to the queue. | 2022-10-19 07:58:32.618 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-10-19 07:58:32.618 Triggering next historical data download in queue. | 2022-10-19 07:58:32.618 Delaying start of download for SPY. | 2022-10-19 07:58:32.632 Mapping WMT-NQTV to WMT-NQTV. Service code: nasdaq_exchange.data | 2022-10-19 07:58:32.652 SC Data - All Services | Starting real-time market data updates for: WMT-NQTV (WMT-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2022-10-19 07:58:32.652 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-10-19 07:58:32.652 SC Data - All Services | Requesting security definition data for: WMT-NQTV (WMT-NQTV). ID: 7 | 2022-10-19 07:58:32.652 Added historical Intraday data request for WMT-NQTV to the queue. | 2022-10-19 07:58:32.652 Intraday data recording state for symbol WMT-NQTV is set to download 'Pending'. | 2022-10-19 07:58:32.652 Triggering next historical data download in queue. | 2022-10-19 07:58:32.652 DTC Client socket (2) | Creating socket. | 2022-10-19 07:58:32.672 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-19 07:58:32.672 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-10-19 07:58:32.672 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-10-19 07:58:32.673 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-10-19 07:58:32.673 SC Data - All Services | Network connection to server complete. | 2022-10-19 07:58:32.715 SC Data - All Services | Starting socket receive thread. | 2022-10-19 07:58:32.715 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-10-19 07:58:32.716 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-19 07:58:32.780 SC Data - All Services | Sending logon request message. | 2022-10-19 07:58:32.780 SC DTC Delayed Exchange Data | Received logon response. | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Successfully connected. | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLZ22-NYMEX -> CLZ22 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESZ22-CME -> ESZ22 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: SIZ22-COMEX -> SIZ22 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZBZ22-CBOT -> ZBZ22 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZNZ22-CBOT -> ZNZ22 | 2022-10-19 07:58:33.287 SC DTC Delayed Exchange Data | Received security definition for symbol CLZ22-NYMEX | 2022-10-19 07:58:33.423 SC DTC Delayed Exchange Data | Received security definition for symbol ESZ22-CME | 2022-10-19 07:58:33.423 SC DTC Delayed Exchange Data | Received security definition for symbol SIZ22-COMEX | 2022-10-19 07:58:33.423 SC DTC Delayed Exchange Data | Received security definition for symbol ZBZ22-CBOT | 2022-10-19 07:58:33.423 SC DTC Delayed Exchange Data | Received security definition for symbol ZNZ22-CBOT | 2022-10-19 07:58:33.423 SC Data - All Services | Received logon response. | 2022-10-19 07:58:33.459 SC Data - All Services | Server Name: SC Realtime Server. | 2022-10-19 07:58:33.459 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-19 07:58:33.459 SC Data - All Services | Successfully connected. | 2022-10-19 07:58:33.459 SC Data - All Services | Trading is not supported. | 2022-10-19 07:58:33.459 SC Data - All Services | Restarting real-time data updates for symbol: WMT-NQTV -> WMT-NQTV | 2022-10-19 07:58:33.459 SC Data - All Services | Received security definition for symbol WMT-NQTV | 2022-10-19 07:58:33.584 HD Request # 173 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-10-19 07:58:37.058 HD Request # 173 | Download start date-time: 2022-10-19 07:37:48.000000. File last date-time: 2022-10-19 07:37:48.803000 | 2022-10-19 07:58:37.059 HD Request # 173 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-10-19 07:58:37.059 Socket (4) | Creating socket. | 2022-10-19 07:58:37.059 Socket (4) | New receive buffer size: 5242880 | 2022-10-19 07:58:37.059 Socket (4) | Connecting to IP: 8.18.161.133. | 2022-10-19 07:58:37.059 HD Request # 173 | Setting DTC encoding to Binary VLS | 2022-10-19 07:58:37.098 HD Request # 173 | Sending historical data logon request message. | 2022-10-19 07:58:37.098 HD Request # 173 | Requesting Intraday data. Start date-time: 2022-10-19 07:37:48. Record interval: 0. Symbol: SPY | 2022-10-19 07:58:37.565 HD Request # 173 | Decompressing data. | 2022-10-19 07:58:37.585 HD Request # 173 | Receiving Intraday data for SPY starting at 2022-10-19 07:37:48.803000 | 2022-10-19 07:58:37.586 Socket (4) | CloseSocket call. | 2022-10-19 07:58:37.586 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-19 07:58:37.586 Historical data download thread signaled to stop. | 2022-10-19 07:58:37.586 HD Request # 173 | Timestamp of first Intraday data file record written: 2022-10-19 07:39:13.623000. | 2022-10-19 07:58:37.586 HD Request # 173 | Received 142 Intraday data records from 2022-10-19 07:37:48.803000 to 2022-10-19 07:43:32.581000 (5.7 minutes) and wrote 141 records for SPY | 2022-10-19 07:58:37.586 HD Request # 173 | Add time&sales data | Remembered last file record date-time: 2022-10-19 11:43:32.581000 | 2022-10-19 07:58:37.589 HD Request # 173 | Completion time: 0s. | 2022-10-19 07:58:37.589 HD Request # 173 | Intraday data download complete for SPY. Unique request ID: 173 | 2022-10-19 07:58:37.589 Removing historical data download ID 173. | 2022-10-19 07:58:37.589 Real-time Intraday chart data file updates started for SPY | 2022-10-19 07:58:37.589 Intraday chart data file opened for SPY | 2022-10-19 07:58:37.589 HD Request # 173 | Enabling Intraday chart updating for symbol. | 2022-10-19 07:58:37.589 Triggering next historical data download in queue. | 2022-10-19 07:58:37.590 Delaying start of download for WMT-NQTV. | 2022-10-19 07:58:37.590 Socket (4) | Socket gracefully closed by remote side. | 2022-10-19 07:58:37.602 Socket (4) | Closed. | 2022-10-19 07:58:37.602 HD Request # 174 | Downloading Intraday chart data for WMT-NQTV to the file WMT-NQTV.scid. Service: nasdaq_exchange.data | 2022-10-19 07:58:38.047 HD Request # 174 | Download start date-time: 2022-10-19 07:20:20.000000. File last date-time: 2022-10-19 07:20:20.469000 | 2022-10-19 07:58:38.048 HD Request # 174 | Using server: ds25.sierracharts.com port 10150 | 2022-10-19 07:58:38.048 Socket (4) | Creating socket. | 2022-10-19 07:58:38.048 Socket (4) | New receive buffer size: 5242880 | 2022-10-19 07:58:38.048 Socket (4) | Connecting to IP: 38.65.8.115. | 2022-10-19 07:58:38.048 HD Request # 174 | Setting DTC encoding to Binary VLS | 2022-10-19 07:58:38.127 HD Request # 174 | Sending historical data logon request message. | 2022-10-19 07:58:38.127 HD Request # 174 | Requesting Intraday data. Start date-time: 2022-10-19 07:20:20. Record interval: 0. Symbol: WMT-NQTV | 2022-10-19 07:58:38.627 HD Request # 174 | Decompressing data. | 2022-10-19 07:58:38.664 HD Request # 174 | Receiving Intraday data for WMT-NQTV starting at 2022-10-19 07:20:20.469000 | 2022-10-19 07:58:38.664 Socket (4) | CloseSocket call. | 2022-10-19 07:58:38.664 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-19 07:58:38.664 Historical data download thread signaled to stop. | 2022-10-19 07:58:38.668 HD Request # 174 | Received 1 Intraday data record from 2022-10-19 07:20:20.469000 to 2022-10-19 07:20:20.469000 (0.0 seconds) and wrote 0 records for WMT-NQTV | 2022-10-19 07:58:38.668 HD Request # 174 | Add time&sales data | Remembered last file record date-time: 2022-10-19 11:20:20.469000 | 2022-10-19 07:58:38.668 HD Request # 174 | Completion time: 0s. | 2022-10-19 07:58:38.668 HD Request # 174 | Intraday data download complete for WMT-NQTV. Unique request ID: 174 | 2022-10-19 07:58:38.668 Removing historical data download ID 174. | 2022-10-19 07:58:38.668 Real-time Intraday chart data file updates started for WMT-NQTV | 2022-10-19 07:58:38.668 Intraday chart data file opened for WMT-NQTV | 2022-10-19 07:58:38.668 HD Request # 174 | Enabling Intraday chart updating for symbol. | 2022-10-19 07:58:38.668 Triggering next historical data download in queue. | 2022-10-19 07:58:38.668 No download requests in the queue to start downloads for. | 2022-10-19 07:58:38.668 Socket (4) | Socket gracefully closed by remote side. | 2022-10-19 07:58:38.703 Socket (4) | Closed. | 2022-10-19 07:58:38.703 |
| [2022-10-19 16:59:44] |
Everything looks good for the data for WMT-NQTV. Are you still having issues with this symbol and not getting the real-time data? When using the NASDAQ TotalView it is necessary to add the -NQTV in order to get the data from the correct source. We are working on getting the consolidated tape for the NASDAQ TotalView that is part of the Denali Exchange Data Feed, but the work is not yet complete and we can not say exactly when it will be ready. There is the other option of using our Sierra Chart Exchange Data Feed and activating the U.S. Equities exchange there. That data does give the full consolidated tape, but it does not have Market Depth data. So there is a tradeoff. If you want to setup the Sierra Chart Exchange Data Feed, then follow the instructions at the following link: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Note that with the Sierra Chart Exchange Data Feed, you do not add the -NQTV suffix, just use the given exchange symbol (WMT for example). Also be sure that if you do not want the data from both the Sierra Chart data feed and the Denali data feed that you deactivate the one you do not want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-10-19 18:31:08] |
Thanks for clearing up things a bit for me. I now understand I wanted the full consolidated tape for equities through the Sierra Chart Exchange Data Feed over market depth data. But after following setup instructions for Sierra Chart Exchange Data Feed I still don't have real time data. I also don't see the [M] indicator next to the symbol in a chart so this could be it in which case the instructions say to notify support because their maybe a symbol mapping issue. I've tried a couple of symbols and none have the [M] indicator, for example AAPL, RBLX, MSFT, so I presume it is across all symbols. The second question I had was can I use Sierra Chart Exchange Data Feed for my equities and Denali Data Feed for my futures at the same time? Is there a setting where I check things off for this way? Thanks again!
| [2022-10-19 18:47:01] |
Ah, I just realized there is a $10.50 fee for the exchange on equities to get the consolidated tape and agreements to fill out. sorry... still wondering about using two data feeds at once though, the sierra chart exchange for equities and denali for futures. thanks!
| [2022-10-19 21:57:37] |
It is not a problem to use both data feeds at the same time. This is why the -NQTV is necessary for the symbols when using the NASDAQ TotalView data on our Denali feed. This separates the data, so if you have the -NQTV, it comes from Denali, and if it does not have -NQTV, then it comes from Sierra Chart.
