Date/Time: Wed, 19 Mar 2025 09:21:10 +0000
DOM Order entery window
View Count: 323
[2022-10-18 17:08:15] |
N195 - Posts: 11 |
Hello, I would like to know how do I open the DOM window. Couldn't find it anywhere. Attaching a screenshot. Thanks. |
[2022-10-18 20:52:11] |
John - SC Support - Posts: 38782 |
If you have a chart open for which you want the Trading DOM, then select File >> Open Trading DOM for Chart. If you want to open a Trading DOM for a symbol for which you do not already have a chart open, then select File >> Open Trading DOM. You can also do this from the File >> Find Symbol window, where there is a button to open the Trading DOM once you have selected a symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
