Date/Time: Wed, 19 Mar 2025 09:34:34 +0000
Trading SP500 Stocks and CFD
View Count: 395
[2022-10-18 16:08:34]
User477249 - Posts: 1
I would like addtionally to check posibilities on trading onthe SP500 stock with shorts (probably CFD) with Interactive Brokers. Currently I do have Package 10 (for trading Futures). Should I chane my packge version. What would be possible addtional cost?
Regards,
[2022-10-18 20:17:35]
John - SC Support - Posts: 38782
If you are doing CFDs, and as long as Interactive Brokers allows the trading (we do not know) then there is nothing you need to change in your package. Additionally, we offer CFD data from FXCM for free, so you do not need to do anything in terms of data - just open File >> Find Symbol and go to the section for CFD - FXCM.
