Date/Time: Wed, 19 Mar 2025 10:03:49 +0000
Upgrading
View Count: 413
[2022-10-18 15:52:22] |
user10000 - Posts: 50 |
I had an issue arise from Rithimic trading setup with historical data so I plan to switching to denali feed and was wondering if i could get package 10 and denali feed for the rest of the month since its nearing the end of the month? I have to renew after this month anyway so i can figure out the best setup for me to start next month.
[2022-10-18 17:10:07] |
John - SC Support - Posts: 38782 |
When you change your Sierra Chart package, your Usage Time will adjust to reflect the difference in the prices. If you actually go from Package 5 to Package 10, then the cost is the same so your time would not change. But, in order to have the same capabilities (Numbers Bars and TPO profiles), you would need to be on Package 11, which would mean that your Usage Time would decrease and your renewal date would move inward. We are not sure what you are asking in terms of the exchange. If this is your first time using the Denali data, then the exchange fee will be free for the remainder of the month, as the CME Group gives a 1 time trial. You will then need to pay for the full month starting on November 1, 2022. Otherwise, if you have used the data previously, then you would need to pay the full amount for the remainder of the month (the exchanges do not pro-rate their fees). To change your package, follow these instructions: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. To setup the Denali Exchange Data Feed for the CME Group data, refer to the instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-18 17:22:41] |
I only need sierra for charting. I make trades via different method so in this case can I just pay for Denali feed and upgrade to package 11 and have data? Or do i need a CQG?
[2022-10-18 17:37:17] |
You need to connect to your live, funded, trading account at least once a month in order to qualify for the non-professional CME Group fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-18 17:47:53] |
Ok. So I would i be able to use package 5 with Denali feed and cqg routing?
[2022-10-18 21:07:25] |
No, you would still need to be on Package 11, as that is required to get the Denali Data as well as to make the connection to CQG (even though it would only be once a month).
