Date/Time: Wed, 19 Mar 2025 09:29:22 +0000
Denali data feed + execution on Rithmic
View Count: 428
[2022-10-18 15:15:05]
progressivetrader - Posts: 5
Is there any way to have Denali data but executing on rithmic?
I have an APEX funded account but I really don't like rithmic historical data. It often fails to download...
I have a Denali data feed which is much more reliable. Is it possible to do it?
Many thanks.
[2022-10-18 16:41:54]
John - SC Support - Posts: 38782
Yes, absolutely, Sierra Chart is specifically setup to do this.
In fact, unless you changed the setting for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds to No in your instance that connects to Apex, then you would be getting the Denali data in that instance.
If you see an [M] after the Symbol in the Chart Header, then you are getting your data from one of our data feeds.
