Date/Time: Wed, 19 Mar 2025 09:52:46 +0000
Time and Sales Window
View Count: 354
[2022-10-18 13:52:35] |
Steve Leon - Posts: 312 |
Is there a way to minimize a time and sales window at the same time when you minimize the chartbook where the chart that "belongs to that time and sales is also minimized or do you have to minimize it separately ? Also when you attach/detach a time and sales window it does not seem to be contained within the chartbook/chart that it is attached to. Just clarifying my understanding of this Thank you |
[2022-10-18 16:25:31] |
John - SC Support - Posts: 38782 |
You need to minimize the Time and Sales window separately. In terms of Attach/Detach, it is not actually attaching it to the chart. It is attaching/detaching the window from the Sierra Chart software, such that when the window is detached, it is managed by the Operating System and when it is attached, it is managed by Sierra Chart. Where you will see the difference is that when the Time and Sale is Detached, you will get a tile for it in your Taskbar. But when the window is attached, there is no tile and if you minimize the window it does not minimize to the taskbar. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
