Date/Time: Wed, 19 Mar 2025 19:04:59 +0000
CONNECTING ISSUES WITH APEX RITHMIC, PLEASE ADVISE
View Count: 704
[2022-10-18 08:11:44] |
radu.ionut.ro - Posts: 5 |
Hello i am trying to connect with Apex , i followed the instruction from each side and still can't connect please advise |
![]() Attachment Deleted. |
[2022-10-18 11:46:40] |
Sierra_Chart Engineering - Posts: 18843 |
You are getting a "permission denied " error. Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-28 12:01:24] |
HELLO, PLEASE ADVIZE , STILL CAN NOT CONNECT MY APEX ACCOUNT THANK YOU |
[2022-10-28 13:44:36] |
We can only refer you to the information here: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
