Date/Time: Wed, 19 Mar 2025 09:14:30 +0000
CME Non professional #11 level
View Count: 654
[2022-10-18 00:22:48]
User72965 - Posts: 115
Well I'm here.
Filling out Non Pro-Professional @ CME? I'm with IB Brokers
See Pkg. "11" needed $46.00 I'll try 11 again~~
This harder on me <>Than You
So 1 CME ?? Be very clear As why where [I assume@ their Site?What I look for..
10 not good enough;DoI actually need 11?? Be Clear > why ?
I sure hope to get Sierra going<>
I'll go to CME and see what I can do..... Same with #11 pkg.
Thx for your Patience& Reply:
Thx Gene :)
[2022-10-18 01:34:02]
Sending image of what I'm Getting~~
You need to look~~~~ Gene :)
Well ?? I did not know if you could use it~~~
Duplicate charts and other things to be changed ???
I've got 2-3 columns on the Left side of screen
And the Buy Middle column Right side = Sell
There's nothing in the Middle column The one
that allows you to change appearence choices {Buy Price Sell
Thx Gene :)
[2022-10-18 06:25:11]
User584084 - Posts: 268
Are you getting real time data from IB?
[2022-10-18 14:57:08]
Price jumping around like a Cat on a hot gridle :)
Pretty sure I have real time This is on all charts~~ # 2 also....
Must be a stting some-where; Also I tried to move it right by
using the bar @ the bottom of the chart.Can be slide to move dates
back7forth: Hoe ever mine i can't> It's like vivid & there's no dates showing on that bar
I think ?? That's the problem =No dates showing.... Just tried to move it to the Left I can ~~ not to the Right
Which is what I need NOW The date says 12-21-31 H'mmm Price working ~~~ Whoops Using ES6-22ES-202212GLOBEX #2 lOOKS
LIKE<<>> BOTH?? June 22[6-22 & 202212 #2 ?? Whats June doing on there?? <> My Small ES Chart No 6-22 it works~~
All I know for now
Gene :)
[2022-10-18 16:39:38]
John - SC Support - Posts: 38782
First, are you wanting your data to come from IB, or are you wanting the data from our Denali Exchange Data Feed?
Second, we need an image of what you are seeing so we can understand the situation. Refer to the following for how to take a screenshot:
[2022-10-18 17:37:54]
https://www.sierrachart.com/image.php?Image=1666114110790.png
Hope I got it wright; Instructions you sent helpful!!
Gene :)
[2022-10-18 20:59:17]
The data you are getting is from Interactive Brokers at this time. That is fine, as long as you are happy with it.
If you want to setup the Denali Exchange Data Feed instead, then let us know and we will give you the instructions.
[2022-10-19 12:14:17]
looks like you got the Shot of the chart ~~~
Data Feed > Included in 11 pkg. ? No charge?
Dependable~There is another Feed available also?
You mentioned Teton also Is there a cost to it???
Is anything come forth on the chart I sent you..
Was my main chart<> Hope you resolve the issue on it :)
Gene:)
[2022-10-19 12:41:54]
Gene:
Below is a link to a Video for setting up your TPO chart in SC.
Date Time Of Last Edit: 2022-10-19 16:53:47
[2022-10-19 14:40:25]
SC Support - Posts: 1943
Hi User72965, if you have the time, lets have a quick chat about your CME Group Data requirements. We can give you a call when you are free.
[2022-10-19 16:22:21]
Spoke to Gene, helped with adding Real-time CME Exchange Top-of-book data via Denali
