Date/Time: Wed, 19 Mar 2025 09:50:13 +0000
Trading Clips
View Count: 322
[2022-10-17 19:51:41]
User623552 - Posts: 69
On the trading DOM it displays the position size as the number of contracts e.g. long 2 contracts of ES.
I trade in clip sizes, for example a clip size could be 5 contracts.
So when I'm trading 3 clips it would be 15 contracts.
Using clips helps psychologically when scaling up or down in position size.
This is because I am still trading the same number of clips e.g. 3 clips. However I can adjust the size of each clip to more or less contracts.
Is it possible to show on the DOM number of clips being traded, rather than number of contracts?
[2022-10-18 14:47:56]
John - SC Support - Posts: 38782
It is not. Only the number of contracts (quantity) is displayed.
