Date/Time: Tue, 26 Nov 2024 13:24:13 +0000
Keyboard shortcuts
View Count: 1366
[2014-05-21 10:36:55] |
Hendrixon - Posts: 130 |
Can you please add the following to keyboard shortcuts options? From Chart Settings window: Hide Values Scale Hide Time Scale Also, can you make the Left Side Scale (price/values) to behave like the right side Values Scale? Meaning to be able to move it with a mouse click drag and to show the current price? As is the left scale is not really usable by itself. Thanks |
[2014-05-22 17:47:38] |
There is a lot of work to add shortcut keys for the Time and Values scale. We will look into supporting Interactive Scaling on the Left Side Scale. But this probably will not come for several months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-22 20:30:49] |
Understood. Is it simple to add access to them to ACSIL? |
[2018-02-19 15:39:10] |
whats1thingnow - Posts: 407 |
From Chart Settings window: Hide Values Scale Hide Time Scale hello, looking for the same thing as this request from 2014 is it possible now? thank you! |
