Date/Time: Wed, 19 Mar 2025 06:29:48 +0000
Not getting any historical data for CME
View Count: 436
[2022-10-17 16:17:53]
ShuvFlowTrader - Posts: 34
Hi, I dont see any historical chart data for ES, NQ etc . Can you pls advice ? I just want to view historical data along with cluster for testing before buying.
Logs--
Historical data service client indicated that downloads are not enabled. Symbol: ESZ22-CME. Data Type: Intraday data. | 2022-10-16 09:35:05.993
Historical data download ID 5 not found when removing ID from outstanding request set. | 2022-10-16 09:35:05.993
Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Daily data. | 2022-10-16 09:35:05.999
Historical data download ID 6 not found when removing ID from outstanding request set. | 2022-10-16 09:35:05.999
Using Bid/Ask average for last trade price for EURUSD | 2022-10-16 09:35:05.999
Historical data service client indicated that downloads are not enabled. Symbol: SPX500. Data Type: Daily data. | 2022-10-16 09:35:06.011
Historical data download ID 7 not found when removing ID from outstanding request set. | 2022-10-16 09:35:06.011
Using Bid/Ask average for last trade price for SPX500 | 2022-10-16 09:35:06.011
Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-10-16 09:35:06.019 *
Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Intraday data. | 2022-10-16 09:35:06.019
Historical data download ID 8 not found when removing ID from outstanding request set. | 2022-10-16 09:35:06.019
Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-10-16 09:35:06.027 *
Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-10-16 09:35:06.262 *
Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-10-16 09:35:06.305 *
[2022-10-17 20:41:31]
John - SC Support - Posts: 38782
You are not getting any data because your account is expired. We have reset the trial for your account since it has been more than 1 year since you used it. You will now be able to get the delayed streaming data to your charts.
