Date/Time: Fri, 25 Sep 2026 08:02:30 +0000
[User Discussion] - pas de flux en temps reel/ journalier
View Count: 718
[2022-10-17 16:00:59]
casimir - Posts: 2
bonjour
quand je veux trader , je n'ai pas de flux journalier, les flux s'arretent la veille a 22h
merci de votre reponse
bien cordialement
[2022-10-17 17:53:43]
John - SC Support - Posts: 48003
What are the exchanges for which you want real-time data?
Also, do you have a live trading account, and if so through what broker?
[2022-10-17 18:15:15]
casimir - Posts: 2
bonjour
je n'ai pas de broker
je trade avec sierra chart
sur le bound CME
bien cordialement
[2022-10-18 14:12:36]
From Google Translate:
hello
I don't have a broker
i trade with sierra chart
on the CME bound
Best regards
The CME Group has a requirement that you have a live, funded, futures trading account in order to be able to get their data at the non-professional rate. Since you do not have an account, you would need to pay the Professional fees in order to get the real-time data for the CME Group.
The other option is to create an account to qualify for the non-professional rates. Refer to the information at the following link for a way to do this for a minimum outlay of funds:
Easy Solution to CME Funded Trading Account Requirement
Once you have the above worked out (whether paying the Professional rates or getting an account setup to be able to get the non-professional rates) then you will follow the instructions at the following link to setup the Denali Exchange Data Feed for the CME Group data:
