Date/Time: Wed, 19 Mar 2025 09:14:30 +0000
[User Discussion] - bid ask market orders column not populating on DOM, other columns are fine
View Count: 514
[2022-10-17 11:38:22] |
greenugly - Posts: 18 |
Hi i have ESZ22_FUT_CME[M]/MESZ22_FUT_CME[M] DOM set up with the following columns in sequence: price, bid size/buy column, bid market orders column, ask market orders column, ask size/sell column. However the bid market orders column and ask market orders column are showing blanks. is there any step i missed? please advise. thanks |
[2022-10-17 12:22:57] |
Sierra_Chart Engineering - Posts: 18841 |
Those columns are the market by order columns: Market By Order Data They require service package 12. We have given you a free evaluation of package 12. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-19 09:16:51] |
Hi, thanks for the reply. I have received the free evaluation but the numbers are still not showing. is there any additional steps i need to take? please advise. thanks in advancec |
[2022-10-19 16:34:52] |
John - SC Support - Posts: 38782 |
Refer to the following: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
