Date/Time: Wed, 19 Mar 2025 09:52:46 +0000
volume va lines study incorrect values
View Count: 406
[2022-10-17 10:24:29] |
User984730 - Posts: 7 |
I have Volume VA lines study set to show POC/VAH/VAL of previous month but lines are incorrect when i check levels on a monthly volume by price chart I dont see whats wrong and i have more than enough days loaded. I have same study for previous week and it works fine |
![]() Attachment Deleted. ![]() |
[2022-10-17 15:45:33] |
John - SC Support - Posts: 38782 |
You need to ensure that the settings are all the same when you compare the Volume Value Area Lines study to a VbP. In particular, the "Ticks per Volume Bar".
[2022-10-17 23:20:17] |
Sierra_Chart Engineering - Posts: 18841 |
Also refer to: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
