Date/Time: Mon, 25 Nov 2024 05:42:55 +0000
Trade Account Order Allocation With Different Symbols?
View Count: 525
[2022-10-16 17:45:08]
User261655 - Posts: 28
Can the "Order Allocation to Trade Accounts" feature be configured so that an ES order in one account is copied as an MES order with a multiplier in a second account? Or is the feature limited to same-symbol only?
Thanks!
[2022-10-17 14:58:59]
It is an exact copy of the order to a different account. Therefore it will always be the same symbol and order type. Refer to the following for the information on the feature:
[2024-03-22 17:44:50]
raheemrazzak - Posts: 41
Will it be possible to request for adding this functionality, where an allocation can be done from a current symbol to the micro of that symbol as well. It will be very helpful. Thank You
[2024-03-22 17:59:34]
All requests that are made in this Support Board are noted. But we can not say when we would get to any particular item.
[2024-03-24 00:54:05]
Sierra_Chart Engineering - Posts: 17169
There is only copying of an order to the same symbol. We would never implement support for a different symbol this way. If you want to trade a micro symbol and have an order allocated to that same symbol, then this is already supported.
