Date/Time: Wed, 19 Mar 2025 04:36:02 +0000
ACSIL tool selects nearby/existing drawings when being applied
View Count: 435
[2022-10-16 10:47:22]
User92573 - Posts: 552
Dear Support
When using my own ASCIL Drawing tools as well as those provided as examples.
I'm finding that instead on placing the anchor for my ACSIL tool in the location selected, I'm instead selecting any SC Drawing or tool that is nearby.
This does not occur with the inbuilt tools which are similar.
Any direction as to how I lock or prevent the selection of existing pre-drawn drawings when applying an ASCIL .tool study would be greatly appreciated.
Many thanks
[2022-10-16 20:10:47]
ForgivingComputers.com - Posts: 1028
This may be what you are looking for: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: sc.BlockChartDrawingSelection
[2022-10-17 11:11:26]
Thank you, I see it in the documentation but missed earlier.
Great help.
