Date/Time: Wed, 19 Mar 2025 09:17:27 +0000
[User Discussion] - Set chasing limit order Xpips away from recent swing high/low
View Count: 480
[2022-10-16 09:36:01]
User810899 - Posts: 10
Hello friends,
I am struggling in finding a way to set a chasing limit order 5 pips away from most recent higher high or lower low.
Example : Recent higher high is at $100 so I set my buy limit at $95. As long as price stays below or at $100, my limit stays at $95 until it is eventually triggered. If price goes beyond $100, say $102, my limit follows and stays 5 pips away from that new higher high. In that case $97.
The goal is to follow until it is triggered.
Same for a sell. 5 pips above lower low until triggered
Would appreciate any help :)
Thanks a lot !
[2022-10-17 20:47:32]
Sierra_Chart Engineering - Posts: 18841
Have a look at this order type:
Order Types: Limit Chase
There is also this study but it is meant for Attached Orders:
Attached Orders: Study Controlled Targets and Stops
Although the source code of it is provided and can be modified to meet your requirements.
Date Time Of Last Edit: 2022-10-17 20:49:40
[2022-10-19 08:48:57]
Thank you for your reply.
Unfortunately the attached orders does not seem to apply to my situation (maybe I should hire someone to code then) and the limit chase, I had already consulted but it does not work. For a mysterious reason it keeps on getting closer and closer to the current price while I wish it stayed 5 pips away from recent higher high or lower low.
Thanks for your reply anyway ;)
