Date/Time: Wed, 19 Mar 2025 04:36:08 +0000
Too much data on number bars. How to tidy up and reduce?
View Count: 789
[2022-10-15 19:44:56]
User755777 - Posts: 2
Dear SC Support
I have the symbol ETHUSD_PERP_BINANCE being used on the footprint chart. When I use other symbols like Gold and GBPPUSD, I dont get an overload of bid ask, volume data in the candle. I have attached images to explain what I mean.
I tried changing the Value Format to 'Large Integer with Suffix' on the number bars study but thats barely done anything.
How do I aggregate this data so that it looks simpler and less messy? Otherwise I cannot trade
Thank you
imageToo much bid ask data makes chart look ugly.PNG / V - Attached On 2022-10-15 19:41:41 UTC - Size: 102.3 KB - 160 views
imageZoom in on candle_so much data.PNG / V - Attached On 2022-10-15 19:41:47 UTC - Size: 131.67 KB - 145 views
imagetried using large integer format.PNG / V - Attached On 2022-10-15 19:44:41 UTC - Size: 138.44 KB - 127 views
[2022-10-16 09:19:51]
Sierra_Chart Engineering - Posts: 18838
Refer to:
Numbers Bars: Adjusting Tick Size For Larger Increment
