Date/Time: Wed, 19 Mar 2025 04:39:20 +0000
What is the update frequency for the $SPX CBOE Index?
View Count: 388
[2022-10-14 23:04:04] |
Techotomy - Posts: 104 |
What is the update frequency for the $SPX CBOE Index? Some indices are slow to update (e.g., 15s), so I wanted to check beforehand before activating. Thanks.
[2022-10-17 13:38:18] |
John - SC Support - Posts: 38782 |
The CBOE Indices data does not update every so often like some of the other exchanges. The CBOE has set a rule that in order to get the data at all, you need to pay for it.
