Date/Time: Wed, 19 Mar 2025 09:58:08 +0000
ICE Data through CQG Feed
View Count: 603
[2022-10-14 16:51:28] |
jatin.agrawal13 - Posts: 7 |
Hi, I am trying to open Intraday Feed for ICE (F.US.QOF23) but it says can't download for this symbol. I am connected through CQG Data feed and I have ICE Data enabled over there. Please let me the issue.
[2022-10-14 17:48:35] |
John - SC Support - Posts: 38782 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-15 05:16:49] |
User146848 - Posts: 124 |
I am a Stage5 client and use Teton. Is there a way to trade ICE with this setup?
[2022-10-15 12:48:28] |
Sierra_Chart Engineering - Posts: 18841 |
No ICE is definitely not supported.
[2022-10-16 08:52:46] |
Can you recommend a setup instead?
[2022-10-16 09:22:15] |
You would use Teton Order Routing for CME Group and then you can use CQG for ICE. So you would be using two different services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-16 19:41:41] |
CQG for ICE data AND order routing? If so, who provides historical data for the last 10 years?
[2022-10-17 15:17:09] |
CQG for ICE data AND order routing? Yes that is correct.Regarding historical data are you asking about historical Daily data or historical Intraday data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-17 15:17:57
[2022-10-18 07:34:30] |
At least the last 2 months of intraday tick data including volume by price data...absolute minimum.
[2022-10-19 14:50:17] |
That data would need to come from CQG and we do not know what they have available.
