Date/Time: Fri, 07 Feb 2025 14:46:05 +0000
Colour the bar which the alert triggered on
View Count: 375
[2022-10-14 13:13:45] |
User266447 - Posts: 266 |
1) Is it possible to mark (or colour) the bar at which the alert triggered? I mainly have in mind to colour volume bar (once the alert triggered), cumulative volume bar and relative volume. Thank you in advance. 2) I also have a problem setting an alert on a trend line and ray line. Could you say how to do it properly, please? |
[2022-10-14 16:32:45] |
John - SC Support - Posts: 37808 |
1) Not specifically through the alert itself. But what you want to do is to use the Color Bar Based on Alert Condition and then set the same condition in that study and then it will color the bar where the alert was true. There are instructions on applying this study to other studies in the documentation here: Color Bar Based on Alert Condition 2) Refer to the following: Study/Chart Alerts And Scanning: Referencing Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
