Date/Time: Wed, 19 Mar 2025 09:42:09 +0000
chart replay slow down for many charts
View Count: 552
[2022-10-14 00:18:07] |
User887126 - Posts: 84 |
Hi, I have about 50 charts that i want to test it using chart replay (its only for testing purpose, i use less than 10 for actual trading). i know in order to maximize performance, i need to use different instances. however, chart replay does not sync across multiple instances. Currently, i load them all in just one instance so i can replay them at the same times. however, my sierra chart slow down so much that it is almost unusable. I researched quite a bit and there is no easy way to do this currently. if i use multiple instances and create macro to start replay across instances #2 and #3 (and so on) at the same times, it still does not load and sync exactly (its close but not exact). Not sure why. I am requesting to please add a function that let us replay charts across different instances. you can also let us link chart across different instances. that will work also. if there is a different way to accomplish this, please advise. |
[2022-10-17 20:51:53] |
Sierra_Chart Engineering - Posts: 18841 |
This is not a feature we would add. One thing that will help is to not use tick by tick data and instead a higher increment: Replaying Charts: Improving Replay Performance / Eliminating Freezing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-17 20:52:13
