Date/Time: Wed, 19 Mar 2025 04:33:30 +0000
How can I 'Tile as Grid Vertically' across a 'Widened Chartbook Workspace'?
View Count: 406
[2022-10-13 20:07:55] |
User14953 - Posts: 245 |
[2022-10-13 20:58:54] |
John - SC Support - Posts: 38782 |
We assume that you are referring to where you have set Global Settings >> General Settings >> GUI >> Enable Workspace Scrolling to Yes and therefore want to use some of the space that is created off the edge of the window. Unfortunately, there is not a way to do this, except for you to manually set up the windows. When you use any of the Tiling options, it is going to fit the windows into the viewable area and not put the windows into the "extended" space. If you are referencing something else that is still not answered by the above, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-16 03:01:01] |
An ability to assign size to 'Widened Chartbook Workspace', e.g. '2 screens wide', or '2 screens tall', would put some zing in this feature. Date Time Of Last Edit: 2022-10-16 03:02:05
