Date/Time: Mon, 25 Nov 2024 05:46:02 +0000
Chart orientation from left to the right
View Count: 448
[2022-10-13 18:27:33]
User798442 - Posts: 7
Is there a study wich would enable to have a chart orientation from right(oldest) to the left(newest data)? Now all charts are by default from left to the right(left oldest data and right newest). Like normal charts now, but to the other side :)
[2022-10-13 20:21:37]
There is not a way to do this.
[2024-03-27 18:33:40]
User734593 - Posts: 39
is it possible that when opening a new chart it opens on the left side?
I'm reviewing about 30 companies, they don't fit on my chart bar, when adding a new potential company to invest in I would like that when pressing "Duplicate Chart" the new chart would open on the left side and not on the right side.... The current default setting causes the newest companies to be hidden and you have to scroll through the chart bar.
I hope that in such a professional tool as sierra chart there is such an option?
I understand correctly that there is no possibility to create a watchlist in sierra chart? If there is no such possibility then it is all the more advisable to be able to add more greyhounds to the left side, so that when you open sierra you have those companies visible at a glance and not somewhere hidden on the right side.
Thank you sincerely and greetings
[2024-03-27 19:20:48]
We are not understanding this. How exactly are your charts setup? Are they attached to the main window or detached? What exactly are you doing in terms of duplicating the chart - how are you doing this?
There is a Watchlist in Sierra Chart. Refer to the following:
Changing the Symbol of a Chart: Using the Associated Watch List
Again, we are not understanding what exactly you are wanting here.
Date Time Of Last Edit: 2024-03-27 19:21:00
