Date/Time: Wed, 19 Mar 2025 04:31:02 +0000
Moving average hull
View Count: 566
[2022-10-13 16:01:41]
Jaydtrade - Posts: 88
I am trying to move everything from my thinkorswim platform to here. The only thing I haven't been sure about is the hull setting. In thinkorswim I have it set to "Close." I dont see that option for the settings in SC. The closest thing is last is that the EXACT same? I need it to be exact not close. See the screen shot below. Thank you!
imageHull close SS.png / V - Attached On 2022-10-13 16:01:21 UTC - Size: 20.47 KB - 105 views
[2022-10-13 16:15:33]
Actually I've been watching them side by side and "Last" for SC is not the same as close on tos. Do you know which one matches their "close"
[2022-10-13 16:15:55]
JohnR - User831573 - Posts: 320
You are correct on Last = Close. That is SC naming convention. You will also come to notice the difference in others calling them indicators -> SC calls them studies. I presume there are others. It all makes sense eventually... even for a slow old guy like me. hehehe
Hope this helps,
JohnR
[2022-10-13 16:24:10]
Look at my screen shots. This is the exact same spot for both plattforms. As you can see they're not the same. Any ideas? Picture 1 is SC 2 is TOS. I need this study to be identical and it clearly isn't. I really want to get the hell away from TOS please help!
Date Time Of Last Edit: 2022-10-13 16:25:42
imageSC close problem 1.png / V - Attached On 2022-10-13 16:23:37 UTC - Size: 5.37 KB - 106 views
imageSC close problem 2.png / V - Attached On 2022-10-13 16:23:42 UTC - Size: 8.22 KB - 100 views
[2022-10-13 17:13:46]
John - SC Support - Posts: 38782
The issue is not the Last versus Close. These mean the same thing.
It sounds like there is just a difference in the way the Moving Average - Hull is calculated between the systems. We give our exact formulation in our documentation, which you will find here:
You may need to see if one of the other Moving Averages works closer to the TOS Hull Moving Average.
