Date/Time: Wed, 19 Mar 2025 04:31:01 +0000
Alert on Color Background Based on Alert Con
View Count: 341
[2022-10-13 14:53:23]
User266447 - Posts: 270
I would like to check if my alerts are correct - I probably have made a mistake somewhere:
a) =AND(C>C[-1],C[-1]>C[-2],C[-2]>C[-3],V>V[-1],V[-1]>V[-2],V[-2]>V[-3])
b) =AND(C<C[-1],C[-1]<C[-2],C[-2]<C[-3], V<V[-1],V[-1]<V[-2],V[-2]<V[-3])
Could you correct me please?
I attached one print screen just in case.
image4.png / V - Attached On 2022-10-13 14:53:07 UTC - Size: 17.85 KB - 94 views
[2022-10-13 15:16:34]
John - SC Support - Posts: 38782
Your formulas are fine. We even put them into a Spreadsheet Formula to check and they show the patterns hitting occasionally for the ES.
What is occurring that makes you think they are not correct?
[2022-10-13 15:53:03]
Too many alerts. Need to come up with some special and a new one. Thank you for your support.
