Date/Time: Wed, 19 Mar 2025 04:31:01 +0000
STACKED IMBALANCE - EXTENDED ZONE UNTIL INTERCEPTION
View Count: 1345
[2022-10-13 10:29:08] |
User898917 - Posts: 31 |
Hello, I have read and reread the Support Board re. Stacked Imbalance - Extended Zone until Interception, and found no further information as indicated in some of the later Support responses but simply got referred back to: 'This study also allows for Extension lines to be displayed, although this is not covered in these instructions.' I then Googled for info and clicked on a Sierra Chart Support link that redirected me back to: 'This study also allows for Extension lines to be displayed, although this is not covered in these instructions.' So, as is often the case with Sierra Chart instructions, I find myself going around in circles and getting nowhere fast. Any clues, please? Thanks grahamdenney.sierrachart@gmail.com My Chart version is 2443 |
[2022-10-13 13:17:58] |
Sierra_Chart Engineering - Posts: 18837 |
So you want to be able to extend forward, a stacked imbalance on Numbers Bars? We have to see if this is supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-13 14:32:15] |
John - SC Support - Posts: 38782 |
The Volume at Price Threshold Alert V2 has the ability to show Extension Lines. Set the Input for Draw Extension Lines to the setting you want. Also note the two other Inputs that affect the Extension Lines: - Draw Extension Lines with Transparent Range - Draw Extension Lines Until End of Chart These items are covered in the following link: Volume at Price Threshold Alert V2 There is not a way to extend stacked imbalances within the Numbers Bars study itself. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
