Date/Time: Thu, 20 Mar 2025 18:31:24 +0000
Move from gain to stage 5 (using teton)
View Count: 517
[2022-10-13 09:03:53] |
User150852 - Posts: 38 |
I am moving from gain to stage 5... Is the info in 3 Months Free Sierra Chart for Moving From Gain Capital, Transact, CTS to Teton Trading | Post: 315503 still relevant? If so, what is the procedure i need to follow? |
[2022-10-13 14:15:50] |
John - SC Support - Posts: 38829 |
Yes, the information in that link is still relevant. The procedure to follow is outlined at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions In terms of the 3 months of Sierra Chart Usage Time, we will get notified by Stage 5 once your account is setup and then we will add the Usage Time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-15 20:56:56] |
Have you been notified by Stage 5?
[2022-11-16 00:11:22] |
SC Support - Posts: 1943 |
Hi User150852, you have your prize now. Thank you for moving to Teton Order Routing
