Date/Time: Tue, 26 Nov 2024 14:47:11 +0000
print screen of a chart does not work now
View Count: 912
[2014-05-20 15:41:47]
User402474 - Posts: 5
Help !
It worked very well a few days ago !
Now When i print ALT (key) + "print screen" (key)at the same time. It does not work anymore.
I must done something wrong please help me to find out what I should do ?
Print screen of a chart is very much important for me to do research!
Thanks in advance
PY
[2014-05-20 19:20:59]
This question is outside the scope of our support other than to make sure that you are not using these keys as a keyboard shortcut within Sierra Chart. Check Global Settings >> Customize Keyboard Shortcuts.
