Date/Time: Wed, 19 Mar 2025 04:45:17 +0000
No data
View Count: 340
[2022-10-12 07:41:11] |
Ju17 - Posts: 39 |
Hello, I have no data with denali in trading evaluator (apteros tryout) can you please help me fix that issue ? best regards ju Software version: 2287 64-bit | 2022-10-12 09:39:17.079 Primary Thread ID: 6288 | 2022-10-12 09:39:17.079 Usage end date: 2023-03-06 | 2022-10-12 09:39:17.079 Enabled for: Advanced Features 2. | 2022-10-12 09:39:17.079 Enabled for: Sierra Chart Historical Data Service. | 2022-10-12 09:39:17.079 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-10-12 09:39:17.079 Enabled for: Delayed Denali Exchange Data Feed. | 2022-10-12 09:39:17.079 Enabled for exchange2: CME | 2022-10-12 09:39:17.079 Enabled for exchange2: COMEX | 2022-10-12 09:39:17.079 Enabled for exchange2: NYMEX | 2022-10-12 09:39:17.079 Enabled for exchange2: EUREX EOBI | 2022-10-12 09:39:17.079 Enabled for exchange2: fairx_exchange.data | 2022-10-12 09:39:17.079 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-10-12 09:39:17.079 Current selected Data/Trading service: Trading Evaluator | 2022-10-12 09:39:17.079 Custom symbol settings values: enabled | 2022-10-12 09:39:17.079 Chart Update Interval: 1800 | 2022-10-12 09:39:17.079 Intraday Data Storage Time Unit: 0 | 2022-10-12 09:39:17.079 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2022-10-12 09:39:17.079 2022-10-12 07:39:17 Local computer time in UTC | 2022-10-12 09:39:17.079 2022-10-12 09:39:17 Local computer time in SC Time Zone | 2022-10-12 09:39:17.079 2022-10-12 07:18:54 Server time in UTC | 2022-10-12 09:39:17.079 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-10-12 09:39:17.079 Program path: C:\EurexSierraChart\ | 2022-10-12 09:39:17.079 Data Files path: C:\EurexSierraChart\Data\ | 2022-10-12 09:39:17.079 OS Version Number: 10.0 | 2022-10-12 09:39:17.079 Locale Setting: C | 2022-10-12 09:39:17.079 DLLs: UserContributedStudies_64.dll | 2022-10-12 09:39:17.079 Allowed protected custom studies: | 2022-10-12 09:39:17.079 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-12 09:39:18.359 DTC Client socket (1) | Closed. | 2022-10-12 09:39:18.359 File >> Disconnect selected. | 2022-10-12 09:39:20.661 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:39:20.661 Trading Evaluator | Disconnected. | 2022-10-12 09:39:20.661 DTC Client socket (1) | Deleting network socket now after delay. | 2022-10-12 09:39:48.370 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:40.904 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:40.932 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:40.937 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:40.937 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:40.937 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:40.947 Trading Evaluator | Disconnected. | 2022-10-12 09:40:40.947 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:40.947 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:42.984 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:42.984 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:42.984 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:42.984 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:42.984 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:42.998 Trading Evaluator | Disconnected. | 2022-10-12 09:40:42.998 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:42.998 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:45.021 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:45.021 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:45.021 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:45.021 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:45.021 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:45.044 Trading Evaluator | Disconnected. | 2022-10-12 09:40:45.044 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:45.044 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:47.048 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:47.074 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:47.074 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:47.074 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:47.074 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:47.094 Trading Evaluator | Disconnected. | 2022-10-12 09:40:47.094 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:47.094 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:49.090 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:49.090 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:49.090 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:49.091 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:49.091 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:49.105 Trading Evaluator | Disconnected. | 2022-10-12 09:40:49.105 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:49.105 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:51.107 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:51.107 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:51.110 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:51.110 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:51.110 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:51.123 Trading Evaluator | Disconnected. | 2022-10-12 09:40:51.123 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:51.123 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:53.149 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:53.170 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:53.170 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:53.170 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:53.170 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:53.185 Trading Evaluator | Disconnected. | 2022-10-12 09:40:53.185 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:53.185 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:55.181 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:55.181 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:55.181 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:55.181 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:55.181 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:55.196 Trading Evaluator | Disconnected. | 2022-10-12 09:40:55.196 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:55.196 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:57.205 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:57.205 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:57.205 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:57.205 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:57.205 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:57.232 Trading Evaluator | Disconnected. | 2022-10-12 09:40:57.232 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:57.232 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:40:59.240 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:40:59.261 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:40:59.261 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:40:59.261 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:59.261 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:40:59.279 Trading Evaluator | Disconnected. | 2022-10-12 09:40:59.279 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:40:59.279 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11096 | 2022-10-12 09:41:01.295 Error getting address info for evaluator.sierracharts.com. Windows error code 11001: Der angegebene Host ist unbekannt. | 2022-10-12 09:41:01.295 * DTC Client socket (1) | CloseSocket call. | 2022-10-12 09:41:01.296 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-12 09:41:01.296 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:41:01.296 DTC Client socket (0) | CloseSocket call. | 2022-10-12 09:41:01.310 Trading Evaluator | Disconnected. | 2022-10-12 09:41:01.310 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-12 09:41:01.310 |
[2022-10-12 08:40:45] |
Sierra_Chart Engineering - Posts: 18838 |
You are running an old version. You need to update to the current version: Software Download: Fast Update There is no other possibility. This version is no longer supported with the trading evaluator service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-12 08:41:00
[2022-10-12 09:01:46] |
Ju17 - Posts: 39 |
thank you very much
