Date/Time: Wed, 19 Mar 2025 04:31:05 +0000
Auto-scaling my Numbers Bars Chart
View Count: 556
[2022-10-11 18:26:56] |
User506484 - Posts: 1 |
4 charts are sharing the real-estate on my screen and I notice that my Numbers Bars Chart is frequently just a blank white screen because the price has moved away from the Price Scale that is visible to me, and I find myself constantly trying to re-center it. Is there a way to keep my charts re-centered automatically?
[2022-10-11 20:25:28] |
John - SC Support - Posts: 38782 |
The primary way to do this is to set the Scale for the chart to Automatic. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) If you want to use a different scale, then you would probably want to use Constant Range so you can set the option for when to re-center the chart. Refer to the following: Chart Scale and Scale Adjusting: Constant Range (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
