Date/Time: Wed, 19 Mar 2025 04:36:07 +0000
Line drawing right click menu
View Count: 347
[2022-10-11 15:27:15]
elevation999 - Posts: 11
Can I get some help on how to change the preset colors for the line tool when you right click. The documentaion states,
(Press one of the colored buttons on the first tab of the Configuration/Properties window to open the Color Selector window.
Press the Define Custom Colors button if the Color customization portion of the window is not already displayed)
When I open up the chart drawing properties I dont see the first tab labeled configuration/Properties. I must be missing something. Thanks for the help
[2022-10-11 16:06:25]
John - SC Support - Posts: 38782
The tab itself is not labeled "Configuration/Properties". We are just saying that you will go to either the Configuration Window or the Drawing Properties window in order to make the change. The first tab will have different names, so do not worry about that.
On that first tab, select the color option (typically the colored square for the particular drawing). This will bring up the color customization window. Change the colors in the bottom row of the Custom Colors on the left to get the colors you want.
