Date/Time: Tue, 15 Sep 2026 09:49:18 +0000
Sub Instance has been corrupted
View Count: 670
[2022-10-11 15:16:31]
User664240 - Posts: 209
What is the easiest way to bring back a corrupted sub instance that crashes during start up while keeping all the old .cht and data files
[2022-10-11 15:52:26]
Sierra_Chart Engineering - Posts: 24870
We are not sure exactly what the issue is. Does not make sense that is corrupted.
What exactly is happening?
Follow the instructions here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Deleting Sub Instances
However, do not delete the Data subfolder in the sub instance folder.
Date Time Of Last Edit: 2022-10-11 15:53:44
[2022-10-11 16:56:15]
Upon Start up the subinstance freezes and is unresponsive
imageice_screenshot_20221011-125414.png / V - Attached On 2022-10-11 16:55:58 UTC - Size: 70.12 KB - 172 views
[2022-10-11 17:43:09]
Step one Save Data folder from sub instance 3
Two Delete the Sub Instance 3 Folder
Three create new Sub instance from the Main instance.
Four exit NEW sub instance 3
Five delete Data folder of New sub Instance 3 and replace with OLD Data folder from original Sub instance 3
Six restart Sub Instance 3
Note this generated Two sub instances inside of Subinstance 3 see pic (note the Title of the Directory Sub..3)
which I deleted and I'm hoping won't reappear when I exit and restart SC Main.
Date Time Of Last Edit: 2022-10-11 17:43:55
imageice_screenshot_20221011-132419.png / V - Attached On 2022-10-11 17:43:49 UTC - Size: 78.34 KB - 168 views
