Date/Time: Wed, 19 Mar 2025 04:33:31 +0000
Problem with Instance 2
View Count: 383
[2022-10-11 07:21:32]
nicktrader - Posts: 746
I am running on Instance 2 two different Chartbooks. Both ended yesterday in M3 with candle of 12:57 and started this morning on 8:33. I closed Instance 2 and started new. Same result.
If I start the same Chartbook in Instance 1 every works fine.
What is the problem? I am running 2445
Many thanks
imageValue Window.png / V - Attached On 2022-10-11 07:14:44 UTC - Size: 11.8 KB - 96 views
imageChartSettings.png / V - Attached On 2022-10-11 07:20:55 UTC - Size: 23.83 KB - 94 views
[2022-10-11 07:31:00]
Sierra_Chart Engineering - Posts: 18837
We do not even know what your question is.
[2022-10-11 08:07:12]
Charts of both Chartbooks stop yesterday at 12:57 and start this morning at 8:33. Close of EUREX = 22:03 and Open 2:15
[2022-10-11 09:22:32]
Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Missing or Incomplete Intraday Chart Data
We do not see any missing data ourselves for a EUREX symbol:
https://www.sierrachart.com/image.php?Image=1665480136157.png
