Date/Time: Tue, 26 Nov 2024 06:57:02 +0000
Can I Distribute a DLL from within a Chartbook (only) to keep it PW Protected?
View Count: 482
[2022-10-10 22:02:48]
User429065 - Posts: 118
Is it possible to conceal and distribute a custom DLL from within an uploaded parent Chartbook so it does not appear in the "Add Custom Study" menu and without losing the ability to turn the user accessibility of it on and off remotely? One of the DLLs is a renamed and password-protected DLL of the "Study Subgraphs Average - Multiple" that I don't want to appear anywhere until the Chartbook where it resides is opened in SC. Until I can learn to build it as a stand-alone DLL, this appears to be the only way I can completely conceal its unique algorithm. Please advise, thank you very much!
Date Time Of Last Edit: 2022-10-11 05:09:54
[2022-10-11 13:35:03]
John - SC Support - Posts: 36286
There is not a way to hide a DLL. If you are sending it to someone, then it needs to show up in the list of available studies. You can password protect the study itself, however. Refer to the following:
Chart Studies: Password Protecting Studies
