Date/Time: Wed, 19 Mar 2025 03:26:44 +0000
volume indicator
View Count: 464
[2022-10-10 20:39:50] |
User183724 - Posts: 194 |
I'm looking for a volume indicator that displays the volume of each tick in each bar and displays it to the left of the bar. ive seen it in chart pictues but dont know what its called. Hope I'm describing it correctly. i've tried all the volume indicators listed and cant find it. maybe its a custom study? thank you
[2022-10-10 21:49:53] |
John - SC Support - Posts: 38782 |
The primary tool for this is the Number Bars. But you need to be on the Advanced package (Package 11) in order to use this study. Refer to the following: Numbers Bars You can also get similar information from the Large Volume Trade Indicator study. Refer to the information here: Large Volume Trade Indicator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-11 04:32:10] |
this isnt what i'm looking for but thanks anyway
