Date/Time: Wed, 19 Mar 2025 02:20:21 +0000
Real time futures data
View Count: 337
[2022-10-10 15:31:29]
Joep Hoffmann - Posts: 2
Hey Sierra,
I have a question about real time data for futures. I currently have real time data with my broker Tradovate. If I buy the Base advanced package can I use my broker to access real time data on the Sierra platform?
Thanks in advance!
Best,
[2022-10-10 17:19:10]
John - SC Support - Posts: 38782
Since Tradovate uses CQG, you can not use that data with Sierra Chart. We do not bring in data from CQG for the CME Group or EUREX. You can, however, trade from Sierra Chart using your CQG account. You would just need to get the data from our Denali Exchange Data Feed. Refer to the following:
In order to connect to an external service (such as CQG), you need to be on one of the Integrated packages (package 10, 11, and 12). Since you mentioned the Advanced Package, you would want to be on the Integrated Advanced Package (package 11). You can set/change your package at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation&UserID=268377#ServicePackage
