Date/Time: Wed, 19 Mar 2025 03:26:44 +0000
simultaneously draw
View Count: 296
[2022-10-10 15:23:07] |
SchulzMatthias - Posts: 2 |
Hi! Can I automatically or simultaneously draw drawings that I draw in the Market Profile Chart in the same instrument in the Footprint Chart? I mean a chart with the indicator "VbP for TPO". |
[2022-10-10 17:06:56] |
John - SC Support - Posts: 38782 |
Drawings can be automatically copied between charts. Refer to the following for how this is accomplished: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
