Date/Time: Sun, 13 Sep 2026 14:57:11 +0000
HI
View Count: 578
[2022-10-10 15:22:19]
User698182 - Posts: 2
HI
I install sirra on my computers but i don't have live date nothing is showing can you help how to fix it
thak you andy
[2022-10-10 17:05:46]
John - SC Support - Posts: 47854
Are you using Sierra Chart with a trading service (if so, what service are you using), or are you just learning the system at the moment and not trading?
If you are just learning Sierra Chart and not using a live trading account, then we recommend that you use our Delayed Streaming Data. We have data from the CME Group, EUREX, CFE, and NASDAQ TotalView available at 10-15 minutes delay (depending on exchange). The data works the same as real-time data apart from the delay. You can also use it with our Simulated Futures Trading Service. Refer to the following:
Delayed Exchange Data Feed
