Date/Time: Thu, 20 Mar 2025 03:19:55 +0000
Sierra Chart is slow/jerky (only in one chartbook)
View Count: 547
[2022-10-10 15:19:15] |
StanThompson94 - Posts: 6 |
Hello, since a couple of days, I have a problem with Sierra Chart: I have two chartbooks. When the first is open, everything runs fine (as it was for the second chartbook before) In my other chartbook, everything was fine too, but since a couple of days, when my second chartbook is open, it seems that Sierra Chart runs slower than before/when the other chartbook is open. The chart is not updated as fast as in the other chartbook and even zooming and the operation of the menu is jerky. I updatet to the newest Sierra Chart version, but the problem is still present. In this second chartbook, i used selfmade indicators and backtested ASCIL-Strategies but even if i remove all those studies, the problem is still present. I am sure it is no problem with my PC, because in the first chartbook, everything is fine. Can you please help me? Thank you and best regards Thomas Winkler |
[2022-10-10 17:01:36] |
John - SC Support - Posts: 38812 |
Refer to the information in the following section: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
