Date/Time: Wed, 16 Sep 2026 16:32:50 +0000
Title bar missing
View Count: 1960
| [2022-10-10 13:29:42] |
| User459170 - Posts: 262 |
Hi, in one of my charts (it is attached) the title bar is missing. In Chart menu, show title bar, show menu and show scroll bar checked. I also unchecked and checked them back, but the title bar still does not show. Please help. Thanks. |
| [2022-10-10 13:43:38] |
| Sierra_Chart Engineering - Posts: 24877 |
Make sure this option is disabled: General Settings Window: Auto Hide Charts Title Bar And Scrollbar (Global Settings >> General Settings >> GUI >> Application GUI) If that that does not help try restarting Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-10-10 13:56:42] |
Hi, Autohide is set to NO. The title bar is visible in the other charts in the chartbook.
| [2022-10-10 15:45:20] |
Restarting Sierrachart did not help fix the problem.
| [2022-10-10 17:11:23] |
We really are not sure about this. If you provide us the Chartbook we can test it. Instructions: Support Board Posting Information: Attaching a File (Optional) We will need to know the chart number. Each chart has a number and this can also be seen from the CW menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-10 17:11:44
| [2022-10-11 00:54:00] |
Window/Cascade fixed it. I guess the problem was probably something else, may be the Title bar somehow got stuck underneath something at the top.
