Date/Time: Tue, 26 Nov 2024 14:22:21 +0000
PROGRAMING WITH ACSIL
View Count: 989
[2014-05-20 11:57:26] |
User82615 - Posts: 106 |
HELLO I WOULD LIKE TO KNOW IF WHEN PROGRAMMING A TRADING SYSTEM OR A STUDY WITH ACSIL IF THERE IS A LIMIT IN THE NUMBER OF CONDITIONS THAT THE SYSTEM CAN HAVE? THANK YOU VERY MUCH |
[2014-05-20 15:00:56] |
No. There is no such limit at all.
