Date/Time: Wed, 19 Mar 2025 04:33:27 +0000
Exchange Traded Spreads
View Count: 447
[2022-10-10 07:41:58] |
User841161 - Posts: 263 |
Right now I use Stage 5/Advantage Futures, and am using Teton Order Routing. I know Sierra Charts has the capability of charting and trading exchange traded spreads but it seems with my current setup through Stage 5, I only have access to minimal amount of these exchange traded spreads. Would there be a broker/FCM that would deal and have more active exchange traded spreads to chart and trade on Sierra Charts.
[2022-10-10 08:28:36] |
Sierra_Chart Engineering - Posts: 18837 |
Any spreads you need to have access to that are not currently available just let us know which ones and we will make sure they are set up on Teton order routing.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-10 08:29:04
[2022-10-13 13:12:24] |
NotIll - Posts: 118 |
How about all of them?
[2022-10-13 13:18:56] |
We need to know specifically what you require. Not all of them.
